How much gas is left in the hose?
WuzzaCBXRider
Ever wonder how much gas and what grade of gas is still in the hose when we gas up our tiny gas tanks? Some of the hoses are very very long and I'm wondering where is the shut off valve in the hose. Is it at the handle or way back at the end of the hose or even inside the pump somewhere? How much fuel do those hoses hold anyway? For those wanting hi octane fuel from a pump with only one hose, how much hi octane are you getting if the previous user bought regular grade?
Blazing-Saddle
"Kowalski"
Hmmmm, never gave it much thought although I do shake out what's left in the nozzle before I pump
BowDown
Well most pumps the hose is attached about 6-8ft up. You get the gas that's in the hose after the pump turns off for the down section. I would imagine the gas in the up section would drain back into the holding tank?
Narcissus
Hayabusa Immortal
I used to drive around till I found a pump that was last filled with 93, but it's becoming so hard these days with everyone using regular. On the bike, I don't care, but my cars require premium.
au03z71
The check valve (or anti-reverse flow device) is at the nozzle.  Whatever the person before you pumped is what you get for approximately the first 10 ounces of gas that you pump but after you fill up (with 93 I presume) the concentration of the fuel in your tank is relatively the same as if you had pumped premium from the beginning.  Nothing to worry about.
Rayabusa0818
Never Forgotten
Not high on my list of concerns...all my vehicles run on regular except the GSXR750. I accidentally put regular in it one day and could not tell any difference.
big jim
This is absolutly correct the average fuel hose is a total of 10 feet. The average is about 1 ounce for every foot of hose (depending on the type of hose on the gas pump, stations that use vapor recovery motors actually only hold about 1/2 ounce per foot.
300Busa
Chillaxin...
I am going to sit around and wait for somebody to fill up with 93, then go buy .50cents worth of 87 octane....over and over and over again. Save myself .20cents a gallon for premium...
MET
The Watcher
No never did wonder. The Turbo is on 93 and up plus octane boost if I am racing. If niot racing it really does not matter for 6 oz
Latest Bikes
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
  • My 2014 Hayabusa
    • Dljat2
    • Updated:
  • Hi Everyone
    Loved
    • BirolBora
    • Updated:
  • 3-wheeler Touring Car
    2002 BMW K1200RS built into a Grinnall Scorpion 3 800lbs 130hp
    • K-Clive
    • Updated:
Forum statistics
Threads
174,138
Members
48,268
Latest member
Profighter01
