I just got done attempting to hook up the cruise control (ccs-100) and can not get it to work.
Can someone tell me if the red led flashes when it is turned on?
I saw a couple different write up that showed dip switch settings being different.
I got it wired to coil with dip switch settings 1,4,7 on with the rest off.
Wired the purple to rear brake light ,
blue to coil, did not cut wire, 19.5 ohms resistance is what it checks out as.
Red, and black to battery.
didn't use grey.
Switch panel (fused wire), and led power wired to brake light feed (key on 12 volts).
Color matched yellow, brown, green between control box and switch panel.
Control box lights up and powers brown when turned on, and gives positive feed to green and yellow when buttons are pushed.
Led goes red when buttons are pushed, and brake light goes on. it has factory tail light.
Any ideas?
didn't use grey.
Any ideas?
