PADEROLIS
Good morning all! I've installed a Rostra unit in my 2008 and am having trouble getting it to work. I've installed the Audiovox CCS100 in the past and it worked great, I used the tutorial provided by Sous, and it went well! I also installed a Rostra unit in my Suzuki Burgman 650 scooter, and it's working great in that! I followed the tutorial pro vided by the threads between Sous, and the one from Captain and TwoTonevert. I wired everything as instructed, the only thing that is not wired in is the ENGAGED LED, but that is an option and not required. The Rostra on my scooter functions without it. The Rostra on the Busa is getting power, and the violet wire is showing 12 volts when the brake lever is pulled or pressed. When I go into diagnostic mode, the red LED inside the servo does not respond when I push the buttons on the control pad.
The only indication I get that the LED is working is that it does a quick flash when I apply the brakes, as long as the control panel is ON. I've triple checked my wiring and my dip switch settings, I'm hoping the problem is still something I may have missed, and I didn't just receive a defective unit. Any help would be greatly appreciated!! Thank you!! BTW, I took it for a test run and it indeed will not ENGAGE.
