hezekiahmunson
I have a 2005 with a Hahn turbo kit using an FMU. It ran fine before my recent changes.
1. Replace little MSD pump with Bosch 044 (amp hog)
2. Fuel cell
3. Moved boost from 6 to 9psi
Around 9000 rpm and 9psi of boost the electricals seem to cut out for a second and come right back. The tach
falls so it seems like its electrical. Its only when getting to max boost it seems.
The FMU is wide open at that point so the Bosch is using as many amps as it can, could it be its too many amps
for the stock stator? Ive tried two batteries and same issue.
Thanks
Frank
2. Fuel cell
Thanks
Frank
