I do, and have for myself and alot of others for many years.
I have used all different types of changers and balancers, including hydraulic changers and electronic balancers, which are nice.
I've used just 2 spoons to change tires, a couple different changing stands, and currently have the Rabaconda dirt tire changer, which also works on street tires.
Rabaconda's street tire changer(which I will be buying soon, $600) is by far the quickest and easiest changer there is, as there is no real physical effort involved, vs their dirt version, which requires some elbow grease to get stubborn tires on, and I am outgrowing that, lol.
For balancing, I have been using the same Redline Stands brand static balancer for about 13-14 years now.
It has adjustable feet, a bubble level, bearing mounts for the wheel shaft, and it works excellent.
My tire balance tests consist of a top speed run, and every tire on many bikes has always been glass smooth.
I use stick-on weights too, not the hammer-on/crimp on style that attach to the center wheel lip.
I also got a Snap-on motorcycle tire balancing machine a few months ago.
It was missing the cones, but my Dad made me a new aluminum pair on the lathe.
Once I finish 2 more bikes, I'm going to pull a wheel off my gsxr and try it.
For the easiest operation, least effort, and least space and weight without electricity, a Rabaconda Street tire changer, and a quality static balancer are your best bet for tire changes.
Still young and tough? 2 spoons and a floor is all you need to mount them...but still a quality static balancer.
Also, I had such a stubborn new front tire on the other gsxr a couple weeks ago, that did Not want to go on the wheel.
So, I put 10 zipties around the tire to close the beads together...and it dropped right on to the wheel!
I never had to use that trick before either, but it works.
