First track day advice?
Blacksmith
Ok so I got my gauntlets today and confirmed that they will have a race suit to use at Roebling Rd on March 14 which gives me 2 weeks to do whatever prep or practice might help me. Do you track guys have any advice or suggestions that'll help me be a little more prepared or know what to expect? Obviously im not trying to set any records I just want to get in and learn as much as possible and not hurt my bike again. Or do I just ride as much as I can before then and not worry about what I'm going to be missing out on? Thanks
c10
Oh trust me I'm not out to impress anybody, I'll be happy if I ride all day and dont get passed by a first timer on an R3!
Hydrate for a few days before . 20 minute sessions for novices are hard if your not in shape . If there is option to pay for lessons while on the track opt for it . A seasoned road racing person can really school you , and make the future laps better , and quicker for you . Eat nothing out of the norm the day before , and rest well that day / evening before . Get your bike ready several days in advance so your not down to the wire . No major mods before the track .
Blacksmith
[QUOTE="c10, post: 3327234, member: No major mods before the track .
[/QUOTE]
I almost ordered a full set of better brake pads since I've wanted to anyway but thought I might need a boy more time to get used to them
fallenarch
THE SLOW RIDER
1. Down load a map of the track layout and start visualizing the lines. That was a huge help at VIR.
2. Remember the turns are continuous not individual events. The fastest way through is the line that sets up the next turn.
3. Setbraking points and move them closer to the curve as you get more and more e
WuzzaCBXRider
No it's stock I haven't done anything ti the suspension either end
I’d want to get rid of as much dive as possible w/o sacrificing the handling. Grabbing the brakes harder and later gets you into the corners faster. Too much dive upsets the front end when turning in. You’ll be knee hugging the rear of the tank more than you think anyway. :laugh:
Blacksmith
Thanks for that I've looked at the track but didn't think about pe running it in my head, I did look at it as individual turns though so that's a great point. I can't wait to get out there
Blacksmith
I think I will get some tank pads before I go but how would I know how stiff I can go on the suspension? I replaced my forks after the laydown but I haven't adjusted anything
Mythos
You're thinking right. Go and have fun. DO NOT try to be competitive. Accept the novice riding group. It will be extremely fast. There will be a lot smaller bikes out there that handle better especially if this is small track.
Do take a riders track class if you can. It can only help at least to get you acquainted. The busa is probably just a little out of it's element on a track. You might not have as much fun you try to hit all the turn in markers. I really don't know if the instructors will get that being that they may have always ridden a lot lighter sport bikes. I just know I made my turn in where I felt comfortable. Trying to watch for marks on the track made me go a lot slower and it wasn't fun. The instructor told me he thought I was going to crash!!! LOL That never happened on either of the two track days I did. Not from my entry or exit on a corner but once from just going too fast to make the corner. I locked the front and let go as soon as I went into the grass. I stayed up. Thank god there was plenty of room.
Learn the hand signals.
You probably will rely heavily on engine braking rather than the brake. That's ok for your first track day.
Try to let bikes that are faster in the corners get around you on the straits. If there's a long straightaway, I would not hesitate to let the busa do it's thing. You have as much right as the slower bikes to enjoy your expensive track day.
Lower your tire pressure a little at a time each session. Hopefully there is someone there who can let you air up. I think I had mine as low as 18 psi front and rear and the bike gripped a lot better. The tires get hot very quick if it's a warm day. With normal 37 psi, my rear tire was slithering all over even engine breaking hard. The air expands from heat and centrifugal force also keeps the tire harder. I probably wouldn't be too aggressive with normal tire pressure.
At the end of the day, the last few sessions that's when everyone crashes. If you feel the other riders are going too fast for you, take it easy and let them get around you. I couldn't hang with the 600s as the day came to a close. No big deal. When I get to do it again some day, I will have no problem riding in novice class again. The people who are in too much of a hurry are the ones that crash.
If it's a cold day, that sucks. You won't be going too fast. One of my track days was early in the year and I just had to go slow. If the tires don't melt, it;s not warm enough. Don't try to push it.
Blacksmith
[/QUOTE
The coach that's coming down for the weekend said it's pretty tight for a Busa he's only seen one on this track before. He said a fast litre bike can hit 170 on the straightaway because the enter and exit turns are long sweepers but otherwise it's a tight course better for 600's than anything else. Is the only track between here and Atlanta though so it's my only option for now. Heres the track map.
It's pretty tight, the straightaway can get fast liter bikes up to 170 because of the wide enter and exit turns buy I doubt I'll get that high my first time. They say it's best for 600's because it's so tight but is the only option between here and Atlanta
ZeePopo
You need to adjust that suspension properly. If not you gonna wipe out when you open it up at a corner. First set sag properly on the front and rear. Ya need a friend to help you out with that. If it's stock suspension ya need to adjust your clickers. Front I say 7 clicks out rebound, 4 clicks out compression. If you are a heavy guy knock down each value down by one. Rebound is on top of the forks. For the rear same settings but remember that location are inverse, bottom is rebound, top is compression. Try those settings on the street and see how ya feel. Also what tires ya using?
Cantab
If there is a Dave Moss type fella there go straight to him and get your suspension set and ask him about tyre pressures etc , chances are he'll know the track and whats right for you set up wise.
As mentioned above water is your friend, healthy food make good choices.
Hold your line and tape up your mirrors so you cant see whats comming up from behind ( that way you can concentrate on what you're doing and not worrying if your holding someone up)
Find out before hand if you need to do anything to the bike to suit club regs, eg lock wire or tape for headlights indicators etc.
How good is your bike fitness ? I would try to ride as much and as far as possible till then.
You dont have to stay out the full 20 (?) mins each session - later in the arvo for me im a bit mentally exhausted
for full sessions, mistakes can creep in, i guess it depends on how busy the day is , it might not be an issue.
Enjoy your day out :thumbsup:
Thread starter Similar threads Forum Replies Date
Quicker Gixxer Seeking advice on a Track bike I'm considering General Bike Related Topics 10
S Track Experience Course at Homestead in Feb - Any advice? General Bike Related Topics 4
jellyrug Track day advice needed General Bike Related Topics 5
DocDrop need advice on launching a busa at the track Racing Technical 15
S Leather riding/track suit, 1-pc, new, size 38 - 40 $290 Safety Gear 4
Quiksilver Trip to the track 1/4 Mile 2
M On track A/F Racing Technical 12
AceRider Track day Videos 3
c10 Hayabusa / ZRX Track day in the future . General Bike Related Topics 5
Grkgrrl New to me baby track bike! General Bike Related Topics 32
Dopey Saddlemen track gel channel, anyone have one General Bike Related Topics 12
B some bikes at the track from this weekend Videos 3
bussassin417 Next Hayabusa.org track day ? The Hayabusa.org Trackdays 6
jellyrug Track day General Bike Related Topics 6
B Track day General Bike Related Topics 8
Mathewrussell52 Track rules 1/4 Mile 10
Quiksilver First time at the track. 1/4 Mile 7
K Extended Swingarm At Track Day Twisties 20
RedBull Lake Perris California ~ American Flat Track . . . So-Cal Gatherings 10
nachaya Pirelli Super Corsa (sc2) Track Day General Bike Related Topics 2
G First Track Day......done Track and Racing mods 6
captain I Get This Way Everytime I Go To The Track Too! General Bike Related Topics 4
G Need Track Day Tire Pressure Recommedations Gen II Busa Information 14
fallenarch 5 Things I Learned At The Track General Bike Related Topics 9
J My First Track Day Videos 10
D Blue Bertha At The Track 1/4 Mile 14
Jeremy Godo Gen 1 at the track (first time) 1/4 Mile 16
S Dunlop Q3 track tyre pressures? Tires 6
fallenarch Second Track Day In The Books. Twisties 20
Kevin Jones technology for testing 1/8th 60' and 1/4 mile off the track 1/4 Mile 12
D Some pics from this weekend at the track 1/4 Mile 7
upgradedbusa Track, Turbo Busa 05 Gen 1 Videos 6
upgradedbusa Track video but full video too. 05 Turbo Busa Track and Racing mods 0
8 Made it back out to the track friday night. Looking for some knowledge 1/4 Mile 15
Kevin Jones Can you help me understand rebound damping as it applies to launching at track? 1/4 Mile 16
GEARJAMMER Rate my track 1/4 Mile 0
Tufbusa Track + Sun = Fun :-) General Bike Related Topics 6
skydivr Sportbike Track Time announces New Rider Incentive Program June 2015 General Bike Related Topics 16
N Charging people for a dirt bike ride on a personal track. General Bike Related Topics 17
fallenarch First Track Day Riding Skills/Survival Techniques 40
fallenarch Busa ready for first track day! General Bike Related Topics 13
C Brocks clutch mod and cushion with track king clutches ok? Engine and Performance mods 8
nachaya Tire pressure for the track General Bike Related Topics 15
GEARJAMMER old muscle cars fron my home track Random Thoughts 8
B New to the track 1/4 Mile 8
C First time at the track in over 15 years tonight (and Im pretty dam* happy) 1/4 Mile 4
skydivr New NCM Motorsports Park TRACK General Bike Related Topics 8
C First run down the track 1/4 Mile 6
Ludicrous Speed Video at the track last night 1/4 Mile 20
pan Mugello Circuit Track Day (Italy) - 26th of September 2014 The Hayabusa.org Trackdays 7
Similar threads
Latest Bikes
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
  • My 2014 Hayabusa
    • Dljat2
    • Updated:
  • Hi Everyone
    Loved
    • BirolBora
    • Updated:
Forum statistics
Threads
174,202
Members
48,300
Latest member
NorthernViking
