Yeah, grab the front brake with the front wheel head high off the ground. That'll bring it down.If you think your gonna flip grab the front brake but beware as the front wheel will come down extremly hard , beets a crash also as mentioned abouve wear proper gear
Lannie
no I did mean front brake my foot is under the brake lever when i wheelie helps to hold on better and allow for peace sign . what I mean with front brake, well if your bring up the front wheel it spins if you abruptly stop the spinning down and i mean quickly . I've used this brfore doing quarter mile wheelie shows at Edgewater Raceway in cleeves ohio.Yeah, grab the front brake with the front wheel head high off the ground. That'll bring it down.If you think your gonna flip grab the front brake but beware as the front wheel will come down extremly hard , beets a crash also as mentioned abouve wear proper gear
Lannie
Just kiddin' Lannie. I know you meant rear brake.
Ummm, yeah, ok. Sounded better when it was a typo...... what I mean with front brake, well if your bring up the front wheel it spins if you abruptly stop the spinning down and i mean quickly .
BTW I just roll the throttle on from very slow speed while puling up on handlebar for me it makes the switch to second and so on, which i also do a slow rpm as poss then third the just roll the throttle on as needed I'm within 75 feet of going full quarter mile on it . Also upon landing right beore touch down a little throttle take the bite out of the landingno I did mean front brake my foot is under the brake lever when i wheelie helps to hold on better and allow for peace sign . what I mean with front brake, well if your bring up the front wheel it spins if you abruptly stop the spinning down and i mean quickly . I've used this brfore doing quarter mile wheelie shows at Edgewater Raceway in cleeves ohio.Yeah, grab the front brake with the front wheel head high off the ground. That'll bring it down.If you think your gonna flip grab the front brake but beware as the front wheel will come down extremly hard , beets a crash also as mentioned abouve wear proper gear
Lannie
anyway it does work if your about to flip try it as the last resort but better be ready for a tank slapper if your not ready for it
Lannie
think about it the inershsa, i know thats spelled wrong, turnind heavy wheel two big roters and thery're sping right if that stops aburptly then the motercyle is thrown forward so if you've let off the gas the wheel is stopped so must the wheelie. I'm not lying I swear to you this worksUmmm, yeah, ok. Sounded better when it was a typo...... what I mean with front brake, well if your bring up the front wheel it spins if you abruptly stop the spinning down and i mean quickly .
