BikeMasterBahrain
This is my first Turbo build which im doing myself, i would like to THANK FRANK FROM POWERHOUSE for all his continued support! All parts and accessories and advice was taken from him
PARTS LIST
*RCC Ecu editor Turbo kit
*Wossner Piston kit 81mm Turbo pistons
*APE Studs
*APE Clutch springs
*APE Valve Springs
*Ferrea Stainless Steel Inlet and exhaust valves
*Genmar riser
*CR9E NGK plugs
*Shintz Clutch slave
*APE High volume oil pump gear
*Cosmetic cylinder head gasket + Base gasket
*OEM Bearings/Main bearings
*Valve seals OEM
*Valve Retainer OEM (coz mine was cracked)
Work is still going on..should be ready next week
PARTS LIST
*APE Studs
*APE Clutch springs
*APE Valve Springs
*Genmar riser
*CR9E NGK plugs
*Valve seals OEM
