Took the 'ol Bumblebee out for a ride this morning.
It started right up, idled perfectly, took it out and it worked perfectly for about 15 kms, I was going up a slight hill with a curve and it "bucked once" I thought "oh, oh..."
I got about 2 more kms and the FI light started flashing but it ran....for a bit then quit....all that was in the screen was FI...it would turn over but obviously wasn't getting fuel....I sat there for a little bit and then turned on the key and the gear indicator came up and it started right up with the FI light flashing....
I figured to beat feet and try to get home and took off with the FI light still flashing...I got about 6 kms and it quit with the same scenario....
I was on the phone awaiting to get hold of CAA (AAA) and decided to try the key and the gear indicator came up and it started....back on and try to get closer.....went 3 kms and same thing, it quit with the FI light flashing and nothing in the gear indicator screen....
I figured this is it, this is as far as I get so I tried to get hold of CAA again, after a couple minutes, tried the key and I was back in business I managed to get home with the FI light flashing and a sinking feeling that it would quit again but I got all the way home..
I shut it down and when I restarted the FI light went out and it is running normally again...
I thought I may have picked up some bad fuel as I fueled it after the last ride the other day and that was the only thing different..
Then I thought it might be the fuel pump on it's way out....it gets hot, shuts down and when it cools again it starts....
In the mean time I drained the fuel and will refill with another sourced fuel supply but I figure it's the fuel pump...
If anyone recalls I had a similar issue last summer and I changed out the teabag filter and never had the issue again...that could have been a precursor to the fuel pump going....I lifted the tank and the fuel pump was cool....
All switches and everything are GTG, I checked each and everyone of them and if it had an issue, that little (-) would show up in the gear indicator screen,,,but there was nothing...
