I hear your concern but there’s not enough flex in the line to touch the rotor.I wouldn’t risk it.Looks like a potential bad day to me but if you like it that’s all that matters. I would make sure it’s secure everywhere and cannot get caught in the rotor or anything.
I’m not sure.I could try it.Is it not possible to route under the swing arm
I gotta order another line if I wanna do that though.Definitely looks better,more factory set up I would do as bumblebee suggested and have a look at other bikes with that set up and copy
I just went out to the bike for another look at the rear.Definitely looks better,more factory set up I would do as bumblebee suggested and have a look at other bikes with that set up and copy
There's the answer to your question you asked..on to the next thing now.....I just went out to the bike for another look at the rear.
Theres no way that rear line is gonna touch.There’s not enough flex in the line for it to touch.
Im happy with that
What do you mean will mine be ‘too tight with the swingarm open’?My ZX-14 aftemarket rear brake had the same arrangement but it was longer and I had enough line to make a bigger curve at the back. It never touched anything. The line ran through a P-clip attached to a mount on the swing arm for the stock rear brake line bracket. I don't think the busa has a bolt hole you could use for a P-clip but a zip tie should do. Remember the line will need to slide through the zip tie as the rear suspension articulates. Look close at that square tube support on the swing arm, I think there is a bolthole now come to think of it. yours is a lot tighter than the one on my 14 so I doubt there'd be a problem with it flopping around. Will yours be too tight with the swingarm all the way open (down)?
Bumble what do you think of my front line routing to R caliper?I couldn’t really see anywhere else it could go.There's the answer to your question you asked..on to the next thing now.....
It looked OK to me, turn the bars left to right and see how it moves...if it binds anywhere....also if available, have some one compress the front end and watch how it moves there too..Bumble what do you think of my front line routing to R caliper?I couldn’t really see anywhere else it could go.
