I am a new Busa owner. I purchased a 2002 with 5500 miles about 3 weeks ago. It had some battery and starter issues when I first got it that I believe are worked out. The battery, starter motor, and idler gear were all replaced. I also added the titanium sleeve to the case.
Now, the motor turns over perfectly and tries to start, but is very stubborn. I have tried both with and without using the high idle lever. If I give it a tiny bit of throttle and then let off while continuing to crank, sometimes it will fire and then die. It will do this multiple times.
I eventually got it started using the above method and then it ran fine. It also started right up when hot. However, after it sat over night, I went to try to start it and had to begin the process all over again.
Additionally, I have changed the plugs (NGK CR9E) and added fresh gas because I believe it sat for a while prior to my purchase. I also charge the battery fully before every attempt and I am not getting the FI light on the dash.
Any suggestions as to what I should check next? I love this bike and want to get it going soon!
Any help would be appreciated! Thanks- John
