'04 Busa and the girl is having a hard time at 9000 rpm. Once I hit 9K she loses power and struggles to go any further. If I shift she takes right off again until "the wall" at 9K....................anyone have any ideas? TIA- Tom
There's guys on here who know way more than me that will jump in. But if you do a search on fuel pumps, you'll read about people with the exact same symptoms where it ended up being the fuel pump.
sounds like it might be an injector problem , i would get a set of injectors or send those out and have them cleaned (mps does a good job with a quick turn around )
sounds like it might be an injector problem , i would get a set of injectors or send those out and have them cleaned (mps does a good job with a quick turn around ).
