Hi there. I'm hoping someone has experience with the in-tank gen-1 pumps.
My pump is toast from tank rust. I found a new replacement on Amazon for $30. The fuel pressure regulator, however, has surface rust on it, so I'm sure if it'll be a problem.
Unfortunately, to get a new regulator requires getting a whole new filter assembly for $250+.
It's just a spring-loaded gasket, so it should be ok, right?
Also need to re-solder the connections and fuel level sensor. I'm guessing this is just a variable resistor, so I should be able to test if it works with an ohmmeter?
