changing base gasket
copskahn
About how much would it lower the compression by changing the base gasket from .012 to .020 on a gen 1 busa.
Johnnycheese
stock should be 10
my books are not in front of me but I do think it was .2
Professor
Hayabusa Immortal
I calculate .25 to .3 depending on what stock is ranging from 10:1-10.5:1 actual to the 11:1 advertised.
copskahn
Thanks for the info..I have a set of 13.5 pistons ready for install and wanted to drop the comp a bit.
OB_John Noonan
Before you poll it apart, is your 13.5:1 pistons dome or flat tops..?
Whose are they (manufacturer) New or used..Price?
John
OB_John Noonan
Are they flat topped?
Trust me this is a very good question...if they are flat tops with the standard valve pockets they cannot be 13.5:1...unless your head has been milled a bunch..
JohnwhoworkedforJE10yearsanddesignedallofthebusapistonsupuntilearly2008
Jay
If it is not a pent roof forging, you can just machine the dome off. Will help flame travel too.
OB_John Noonan
Do not machine the dome off of any piston until you verify the current dome thickness and how much you may need to remove.
I have a 1397cc 220 hp JE pistoned Busa and like the power, for another $400.00 dollars or less you could have gone with a 1363 or 1397cc kit..
Either way I am sure you will enjoy whatever power increase you will gain.
John
