Big dumb question... how often do you lube the chain? I'm coming from Harleys, and the last chain-drive bike I had was my GS1100GEZ in 1984. FWIW, my Bus has 1350 miles on it and had the 600-mile checkup.
I typically just give my chain a quick clean and lube every time I wash my bike which is about once a month. If you ride more, you'll need to check it more.
Some folks say every other tank of gas, that would be once a week for me as I go through about two tanks a week (and haven't really deemed it necessary yet).
Just keep an eye on it, if it starts to look gunked up and dirty, clean it up and lube it, if it looks pretty clean still, don't sweat it.
But either way, I'd probably give it a good once over every month. Only takes 10 minutes or so.
I think the manual says clean it in 600 mile intervals - the guy at the dealership told me I could prob go 1000 mile intervals - so I go in between the two or as the chain needs it.
No - leave it on side stand, or have someone sit on it, and use the adjusters on each side. Very easy to do. Use the "notches" to make sure each side is even.
I lube and clean my chain every 500 miles gererally. However if I've been riding really hard or I been in the rain, I will clean and lube it at the end of the ride.
If we are to believe that the chain really expands or stretches that much after a ride when hot....then I would adjust it when its cold and maybe have it a little loose when hot. The alternative is adjusting it when its hot and then having it contract when it's cold and having it too tight. I don't want it too tight and binding up on the sprockets so....I'll adjust when it's cold but I don't really think it changes that much.
