Not to thread jack- but when you say noise, what is it like?
my front wheel has a squeak to it as of this spring, and what I noticed is after i moved it from sitting all winter the front disc seemed to be stuck in place.. a small jerk and it broke free and rotates fine, but moving <3-5MPH and it has a very low dB squeaking noise..
same situation? need i worry about this problem or am I looking at a different one? is this common / normal, and just some rust/debris that needs to be worked off the disc?
Colton
That sounds like rust on the rotors/brake pads to me, give it a few good hard stops and see if it goes away.
how do ya use a gear puller to install wheel bearings? I wouldn't wanna marr up the wheel or rotor carrier by seating the puller aganst either
Posted via Mobile Device
Colton
This scared me so much, I went home at lunch time and checked both wheels with the bike on stands. I'm a bit of a nerd that way.![]()
