I am no master tech but i do all my own maint'. This a pretty old topic that comes up once in awhile.
1- valve clearance specs on the Bus -- have a large range of acceptable clearance .. on the exhaust it's .10mm
to .20mm... if one valve is close to .20 you will hear it.. ticking at idle..as mine has done for 31K ..
2- another source of racket comes from the crankshaft gear that turns the clutch basket...cold and at idle
it can be pretty loud..pull in the clutch in neutral and it goes away = normal Busa sounds.
3- diff topic --shifting ---- gets better and better as the miles go on.
4- This is where things get scary.....I wish an expert would chime in on this [ Johnny Cheese ] ?---------
I have done quite a few oil and filter changes at this point-- most of the time the oil pressure light does
not go off for a very very long time before the oil pump primes itself WHY?
? one minute or more with no
oil pressue is very bad..scares me every time......
5- The last time was a nightmare...most of the time i drain the oil hot..as per manual- the last time
however i drained it cold for hours then i pour abit of clean oil with the plug still out to flush out the
last bit of dirty oil....install drain plug..fill it up Valvoline MC spec 10/40.. started it up and holy cow
souned like a little man with a hammer was inside the engine....even though this time the oil light went off
pretty quick... the only thing i can think of was one valve was hanging open just enough to make a very loud
tapping noise-- suddenly it sounds fine --- and im stumped... so i worry awhile about it.. then a day
later i do 754 miles in 2 days..beating on the thing pretty hard here and there.. no prob's. Now i worry about my next oil change. Ps my poor ol' Bus has been on the revlimiter many times.. if go out right now and
start it it sounds like the day i bought with 2,062 miles on it...
