Two battery guys try a Lithium battery?
jimbob8915
I just bought a replacement battery for my Busa. I bought a lithium battery with a CCA rating of 280. I noticed that the factory CCA is around 170. I know that if you go really high compression people have had to install a second battery for the higher voltage. Can these newer batteries fix this old issue? I ask because I am entertaining a high compression big bore and cam setup.
Hi will have a turbo bike I am getting the battery that Powerhouse sells with 720 cranking amps.
