Ok, this is a weird one. I replaced my conventional battery with a Battery Tender Lithium. First ride the ABS light comes on. I checked the error codes and it was 47: Over voltage. I followed the trouble shooting and everything looks good. I deleted the error code, and after a couple of miles, it came back on. I've done it a couple of times. Always the same error 47, always deletes until a couple miles into the next ride.
Here's where it gets weird. I put the stock battery back in and the light stays off. The only place a Lithium battery will show more voltage is resting (13.4v vs 12.7). Anyone know the ABS system enough to make some recommendations? Company that makes the battery was clueless. Has anyone else run a lithium battery on a ABS Hayabusa?
