(coop65sr @ Oct. 21 2006,19:32) Yeah, I secured the airbox to the side of the bike so that I COULD hook the green temp sensor and the small hose under the center of the airbox up before I even started to initially do the adjustments...
I just went back out there and clamped off the right side hose on the #4 throttle body and did another adjustment on all four bodies. I did not see where the haynes manual said to block off that rt. side hose on the #4 throttle body, so I did not clamp it off when I did my initial adjustment and everything went sooooo wrong-
I went back AGAIN and looked at the Wag's throttle body sync thread (NOTHING AGAINST YOU WAG===I JUST AM TOO NEW TO THIS TO HAVE REALLY BEEN ATTEMPTING IT IT LOOKS LIKE)
As I said, I didn't see anything about clamping off that hose in the two pages that were excerpts from that haynes manual, but when I read on down through the other posts, I noticed where (I think it was actually wag doing his throttle sync) he had ALSO clamped off that rt. side hose on the #4 throttle body.
So I went back out and clamped off that hose this time and retried the adjustment again.
I adjusted all four bodies to about -4 inHg ( inches of mercury)
Now, the FI light has gone out, it WILL idle now...
It still is running really rough though- it will set there and idle rough at about 1150 rpm's, and it erratically is doing an rpm surge every so often. You can tell it is just running rough.
Also, when I rev the engine up with a quick throtlle roll and let off quickly, it doesn't come back down to idle quick enough.....it kinda lags slightly back to the idle rpm
anyone with ANY HELP WILL BE GREATLY APPRECIATED
