JOKERJ
Replaced my front and rear sprockets. Now it is hard to turn the rear wheel. I used a torque wrench to 105 lb-ft. Before I go backing everything out are there any ideas on what I need to check?
The front sprocket is tightened to 105 lbs-ft.
The rear axle has not been tighened fully but enough that it should matter.
The chain is not too tight, even though the bike is up on a rear stand.
The rear rotor is not grinding.
Thanks
Thanks
