boosz
Just wanted to help anyone out who has upgraded to LED signals and wants to SLOW down the flash rate, WITHOUT installing a BIG (heat generating) resistor that is sold as "THE FIX" for your quick flash rate... All that you'll need for this mod is an AUTOMOTIVE electronic flasher that is available at ANY automotive parts retailer, a couple of tie wraps, wire crimps or solder and shrink tube, terminal removal tool or ground down slotted screwdriver, wire crimper, two female spade connectors...and about an hour of spare time
<!--EDIT|boosz
Reason for Edit: None given...|1117377405 -->
<!--EDIT|boosz
