fastball44
I'm going to change my own oil on my O5. I have all the hex bolts removed on the right cowling. Down by the bottom of the tank, I seem to be hung up by the small plastic cover. How do you remove this? Do you just pry it up. It appears to be pictured in the online manual with a dotted line called "A". Any helps or trick to removing the cowling would be much appreciated. Thanks again for all the help.
Jim
Jim
