From memory and I'm an old man, well not quite as old as Ba Busa, but back on topic.
Remove both mirrors by pulling back on the rubber exterior near the base and exposing the nuts or screws. My '06 had nuts, two on each side. Remove the push pins so the interior pieces near the instrument panel are separated from the nose, pull out gently near the mirrors so the nose will clear the mirror mounts and ease the nose forward. When you get it off a bit you'll need to reach in and disconnect wiring or a wiring connector. Purely from memory. I'm going off to do a search now. Several years ago HeavyBusa did a step by step with pix.
