SpeedGeek,OK,your using "MP3" earbuds,what is the manufacturer of the earbuds?..and do they stay in place???..you listen to music and the radar detector...I spliced/soldered mine into my MP3 Right channel earbuds. My MP3 is mounted on the triple tree, and the detector sits on the "dash". Both audio outputs are routed discretely and spliced together under the left fairing panel. I then routed it to an audio jack that comes out under the edge of my seat.
I put in my earbuds, put on helmet and once I et on the bike I plug into the audio plug under the left edge of my seat. Music plays stereo in both ears and the detector only goes off in my right ear. It works fantastic and has saved me more times than I can count (including Saturday when I was over 100 before slowing... close call!)
*NOTE* You need to use the Escort ear phone plug for the detector... it is a MONO plug. Standard earphones are Stereo and you will have issues with it cutting in and out if you try to use a standard 2.5 MM stereo earphone plug.
I and many of my friends use the H.A.R.D. (Helmet Assisted Radar Dectection) and I don't leave home without it. A little spendy but well worth the $.
