JRivera2002
Okay, so I'm planning on ripping my 2008 busa down this summer and I'm going to run ss valves with 65lbs ape springs and ape retainers in the head... but I'm not sure what I should do as far as pistons and rods go. My question is, should I go with stock bore and compression and use the spacer to make the lower compression? Or do I buy lower compression pistons and do away with the spacer? Also, I'm new to the rod thing, do they make low compression rods? I believe they do, which brings me to another question...do I buy lower compression pistons and rods?? lol Anyway, I'm looking for suggestions here from experience, I may be looking to hit around 400hp but no more than that on the street, and I want the motor to be solid. Thanks.
