i posted a topic here a few days ago about a major fuel injection problem but that is not the case. Apparently the older busas had an oil catch tank on them where the crank case vent is. But the manual says it was eliminated on the 2000 models. My problem is that the bike seems to be pulling enough vacum at idle to pull oil from the crank case up through the tube into the airbox therefore dumping straight to the throttle bodies. Engine oil is exactly where it is supposed to be ( just changed it yesterday) and still smokin and sputterin. I took the hose off the air box and plugged the air box rode her for about 2 miles and shes all cleared up. I have a couple of qustions# 1) should i try and find an oil catch tank from an older busa and retro fit it to my 02. # 2) what is under the breather cover is there some sort of baffle in there to prevent oil from being drawn into the airbox? Uh 1 more question how do you get the breather element out of the airbox?
