If done from the top, 2 plastic trim pieces per side, 1 over and 1 under the guages. Guages held in by 2 bolts. Windshield isn't removed. Plastic under nose (if u choose), 6 push/snap connectors.
Don't be afraid to grab hold of the piece over the guages. Pull straight out from one side, then the other, it's just snapped in place, nothing is behind it, no screws.
WarbirdII also posted how he stacked his ballasts on the right ram air tube. This is what I did, zip tied them to it, clear the trim too when u reinstall it.
Also, if u remove the plastic piece under the nose, u can easily reach the bolt to adjust the headlight. Turn one way to raise, obviously the other way to lower. And you can't aim them independently, the whole headlight assembly moves together.
It's a simple job, you shouldn't have any real problems, hope all goes well.
