SavageRock
Good Day everybody.
My ignition became sticky over time and the grooves on my key were wearing. Due to my resistance to getting a new key, simply because the old one was red, to match her of course... Has now broken off and I am now in the middle of the ignition swap... Something that should've been quick, has now morphed into a two-day ordeal! I have pulled the triple tree off to the part where you are supposed to be able to separate the bracket from around the top of the forks, but the thing won't budge. Its supposed to slide off once you release the pressure around the forks giving you access to the ignition cylinder right? Are there screws somewhere on the bottom holding the bracket to the bike?
