Tajh Barber
Goodmorning
I have a gen 1 2007 busa key broke inside of the ignition, I followed a different thread of swapping the stock ignition with a toggle switch, even with the 100 ohm resistor put into place of the wiring. Still no power
I said screw it and called it locksmith to remove and remake a key. Now the key turns in the ignition but no power. No gauge lights, fuel pump does not turn on.
Battery is good
Main 30 amp fuse is good
Any ideas or wiring for the kill switch ignition delete or rewriting the stock ignition ?
Battery is good
