Shrews
I just got done doing the ddm tuning hid mod. The problem I am having is strange. I read were if you hook up the high beam and it dosent come on that the plug just needs flip. Well I turned on the high beam and it comes on for a sec then goes off, but if I then turn the high beam off then back on it comes on and stays on. Is this the plug needing flipped or is this just the way they do. Also my high beam did not come with a oem plug, it was like the low beam as it had two ends that slide in to the oem plug on the bike. They fit perfect. The low beam comes on and stays on no problem. thanks for the help.
