I bought a new enclosed trailer and I want to wire it for 120V. I have a Generac 55KW generator that has a 50 amp plug on the front panel. What I want to do is install a plug in on the outside of the trailer so I don't have to run extension cords through the door. I assume I'll need to run the wiring from that female plug to a breaker box, then run the wires to the lights and wall outlets. My question is this. Although I will only be running power to 4 outlets max, and four 4' florecent lights, I may install an AC unit at a later date. What kind of breaker box should I be looking for, and where can I buy one. Do I need a special box for an RV, or will the same box that you use for residential service work. In addition to the 4 lights, the only big thing I'll be using thruogh the wall outlets is a small air compressor. I'm confident in my ability to run the wiring as I have done a little of that type of electrical work, but selecting the main service box is new ground for me. Any help you guys can give me is appreciated!
