HELP.... F1 light
delboy
God save the Queen.......
Hi Guys and Gal, have just had the Clutch rod seal renewed, engine out etc....
I am now to the point where the engine is back in the bike and all components are reconnected. Obviously not correct as I have a F1 light up ???
Has anyone a list of the error codes so I can backtrack :bowdown::beerchug:
I have ones for a gixxer but not sure if they are the same on the Busa
You can jump the plug and put it in dealer mode to find out just what code it is
i think this is the right list:
c00 none
c12 crankshaft positions sensor, pickup coil signal, signal generator
c13 intake air pressure sensor #2, for front cylinder
c14 throttle position sensor
c15 engine coolant temp sensor
c17 intake air pressure sensor #1 for rear cylinder
c21 intake air temp sensor
c23 tip over sensor
c24 ignition signal, coil #1 for rear cylinder
c25 ignition signal, coil #2 for front cylinder
c28 secondary throttle valve actuator
c29 secondary throttle valve position sensor
c31 gear position signal switch
c32 injector signal #1 for rear cylinder
c33 injector signal #2 for front cylinder
c41 fuel pump control system, fuel pump, fuel pump relay
c42 ignition switch signal, anti theft
c44 heated oxygen sensor
c49 pair control solenoid valve
Sorry Guys its not showing a code, just F1, but it seems juiced right up, should the code show on the screen below the oil / F1 light :bowdown:
You have to put the bike in dealer mode to get the code to show.
Right Guys found the dealer mode terminal, and have routed so its easy to get at, the following errors are recorded
C21 - Intake air temp sensor
C13 - Intake air pressure sensor
are these a biggie and which is which, pictures would be great my friends :bowdown:
Both air temp / pressure sensor tied back out the way by my tuner, have now connected them and the F1 is out, will see him friday to check out the ECU / PC III / Custom Map is working OK :beerchug:
