F1 light and Oil light after installing Titanium Case Protector
maybe the idler gear isn't seated all the way and it's binding up against the cover when you tightened it down. You mentioned the sleeve didn't seat flush with the post...is it like 1/64" sticking out, or closer to 1/8"?
Is there a clicking from the relay when you hit the starter?
Yes relay is clicking and it sticks out 1/64 or 1 mm. I think part of the problem with the seating all the way is the titanium ring got a little flattened when I tried to made it flush. I guess it won't go on anymore...???
Correct.
I then dissassembled as if installing the mod....
Did the ecu trick which gave me a code of "-C00" and the F1 light was no longer lit...
the oil light is still lit and still not turning over....
It's either in gear with the side stand down...or the kill switch is in the off position.
That will cause a no start and the lights to be on.
Posted via Mobile Device
nevermind the speed sensor or any of that. I got the code thing to register and it gave me "-C00" and the F1 light is no longer on....?? ?????? I've changed nothing but disassemble everything for the titanium ring and the oil light is still on.
C00 is no code. Make sure you have wire contacting wires in plug.
Thanks guys it was just the side stand switch was stuck while the side stand was up. However when It turned over it's obvious I did something wrong when reassembling the idle gear and cases. Nothing but a spinning noise. Nevertheless, thanks for the help with such a simple problem. yea I forgot the neutral part. Thankfully nothing bad happened. I do have to take it all apart though. I messed up somewhere.
Told ya...side stand or kill switch...
Your Welcome!
Your Welcome!
Thank you. Fingers crossed I don't mess anything thing up with this idle gear crap.
Ohh in one or two of my pics previously posted there are what seem to be cracks on the crank case. Are they cracks or casting marks?
Looked like a casting mark...you might have to replace the Ti ring if it won't fit right...you kinda beat the hell out of it...
LOL sucker wouldnt go on. If it doesn't fit... hit it harder....I'm starting to lose patience with this thing. I've be fixing/breaking stuff since last March. I've rode it once since then and that was only 20 miles or so. It's wearing me down.
Can you even get the ring off? I don't see how you could do that?
well I see this one was corrected:thumbsup:
Amazing how you can fix bikes through the internet:laugh:
He found the problem brudda.
Still strugglin' :( :(
I know it's been a few weeks I just can't find the time to get her straightened out and rideable. The original problems (F1 light and oil light) were fixed and I thought I had corrected the starting problem, which was the stand switch, BUT engine isn't fully turning over when in neutral. Earlier in this thread like 2 weeks ago BA BUSA helped me to get it to start. When I started it at that time I didn't put it in neutral and heard an off sound when engine turned over. I assumed it was the idle gear. I disassembled everything (4th time) and made sure gears were seated well and all was in correct order. In my novice opinion, everything looks/looked great. I buttoned everything up and go to start it....the engine tries to turn over but it sounds like something is keeping it from turning over????????? My first thought was the battery so I went out and bought one of those, charged it, and turning over but struggling to do so. If the case bolts were torqued too much would they keep it from turning over? Any knowledgeable Orgsters close enough to Northeast Tennessee to come have a look? I'd happily pay you for your time and gas.
