I have installed a Gen 1 in a daily driver car about 5 years ago. The electrical system is powered by an external alternator belted from a pulley threaded into the rh end of the crank, similar to the blower setup. The method supplies all the necessary power for the AC unit, power window/seats, stereo amp, lights, etc. The original generator and rectifier are wired into the system EXCEPT a 30amp inline fuse is removed from the 12v output lead of the rectifier. Thus, the sys is isolated. My thoughts are that if I ever break the alternator belt, I could always install the fuse and limp home on the generator. All is well until last Sunday in the rain on the highway. The car filled with black smoke. I immediately noticed the rectifier was HOT, very hot. So I separated the generator from the rectifier at the connector approx. 4 inch from the rectifier. One of the mating 3 yellow leads from the generator and from the rectifier at this connector was fried and the black insulation material in the rectifier melted and ran down a bulkhead. The rectifier cooled down. No fuses in the primary elect sys blew. After 200 miles since this happened, I do not notice any further issues.
1.Could the cause be water got into the empty inline fuse socket closing the circuit and 12v from the alternator is not compatible with 12v from the generator? Would installation of a diode be a good idea? Keep in mind, my intention is never to use both sys at the same time.
2.Since the generator is intact and operating but not linked to anything to consume power, is this a bad thing?
3.If after a thorough examination of the generating sys wiring I find no chafed wires or other problems and each of the 3 yellow leads from the generator produce ac power, would replacing the rectifier be ok?
From San Diego and on temporary assignment in Greensboro, North Carolina: anyone offer a local competent repair/racing shop with routine maintenance?
By the way, my engine mod and swap was performed by Downs Engineering home page
