mike1180
Banned
I have helped my shifting from first to second.
In experimenting, I:
1. Took off the rubber off of the shift lever ( I have determined that that was part of the problem)
2. Found a die that was close enough to put a thread onto the shaft ( you can do metric or British)
( PS: You can always reverse this procedure and put the rubber back on over the now threaded shaft)
3. Found a piece of aluminum round stock that was the same diameter as the rubber on the original shaft.
4. Cut a piece of this stock to be about 1 ½ inches longer than the original shaft.
5. Drilled and tapped this piece of aluminum stock with the same size treads as in #2
6. A bit of loc-tite and screwed the stock onto the treaded shaft
And voila, a 1 ½ inch longer shift lever without needed aluminum welding, and which can be turned back to stock.
Now"¦ I seem to be able to shift with no problems at all. Bang it into second, all through the powerband and no missed shifts??
Go figure"¦ trying to pigeon toe shift that short a$$ rubber shifter was all of the problems (for me).
What a simple fix and what a joy to shift now!
Natural foot position, good purchase on the shift linkage and all the problems are gone!!
Took me a while to stop hunching my whole foot into that short shifter pattern, but now it is as natural as apple pie!
