ItsDooomz
I bought the Ryan Schnitz Racing RSR air shifter kit https://store.schnitzracing.com/rsr-air-shifter-kit-suzuki-gsx1300r-hayabusa-99-18/ and installed the direct shift air cylinder this weekend. It's a trick piece. Mounting the solenoid directly to the shift cylinder is the way to go and this piece is especially nice with its billet CNC anodized aluminum housing. I went with the traditional engine bolt mount and used the DME Racing top mount https://dmeracing.com/product/suzuki-hayabusa-shifter-top-mount/.
Installation was simple and took about 30 minutes. The hole in the top of the direct shift air cylinder was too small and required drilling to accommodate the DME mount. The clevis on the bottom of the shifter was also to narrow for the OEM shift lever. I took a 80 grit flap wheel to the shift lever and it cleaned It right up. I did it on the bike without removing the shift lever.
