engine ice ice baby
teamorion22
so i flushed the radiator twice with distilled water then put the engine ice in and swang my bike back and forth and tapped on the radiator and hoses in an effort 2 get the air out. Here's my question. There is no way i got all the air out by doing this. Is the little bit of air that is still in there ok? Is there anything i should be looking for or keep my eye on?
thanks
michael
lean the bike side to side as best as you can.....start it up .....drive it for a few minutes and let pressure build up and then cool down....check it again.
DD
You can also squeeze the hoses to push the air up to the top. Cycle the bike a few times, rock her back and forth and squeeze the hoses a few times and you should be all set. After that take her for a spin, bring her back and top off the fluid.
