electrical help
07vigorblue
Is there a wire in the main harness that only gets power when the bike is turned i need it for my shift light
Aquaman
Banned Permanently By MC Mustang
should be in the ignition. there should also be an aux plug in the nose
Strife
Brownish colored wire in the nose it has a female end on it. It's what I used to hook up my switchbacks for the running lights part of the install.
Hayabusa2005
As above, aux up in nose...right side I believe near turn signal.
DEMMYM
Just dont cut the Red Wire, Or is it the Blue wire, No No its definatly the Green wire, Whatever you do dont cut the Red with Blue and Green Stripes wire.
goodluck
boosted finally
i use the aux plug in the nose for power right side by the turn signal just and extra plug hanging there i believe its got a brown plug
DropBusa
33pin ECU plug, its number 1 wire. White with light blue stripe.
