Hello all
Long time member, first time poster! I finally saved up and bought a 2010 Hayabusa last August. Been having a blast, what an amazing bike! You just gotta LOVE that power band this puppy has, WOW!
Any who, I had to remove the oil pan the other day B/C of a striped plug. I drained the oil, removed the oil filter, removed the exhaust, drained some of the coolant, removed the pan, and then tapped the hole. Then I replaced the pan, mounted the exhaust, hooked up the coolant. So far so good. I then topped up the coolant and added the oil, all was good, so I thought. It was weird, I noticed some tiny bubbles in the oil check window when I started it up, the window also seemed like it was a little fogged from moisture. Its been so damn foggy and rainy around here for the last 3 week, it was hard to tell! I didn't think much about it. Went for a little cruise and came back. Something just didn't seem right. I'm going to change the oil & filter again, just in case. Is it possible a little coolant got into the oil? How?
Thanks!
Thanks!
