Thank you so muchYou will need the PC for an a/f map with an AlienHead.
You'll need an ecu flash to have the top limiter removed, along with a few other changes. That will remove the fuel 'soft cut', and ups the rpm limit by 600.
The fuel 'hard cut' remains and IS the rev limiter.
You still can't go faster than 197mph.
You'll need a -2 rear sprocket(41t), or a 55 series rear tire(taller), no mirrors on, and good conditions, then 202-203mph is possible.
You're welcomeThank you so much
So should I not purchase the PC and just find someone to flash the ECU for the A/f map?You're welcome
Yeah it can be a bit confusing. I called a shop and they said they didn't have the software to flash ecu so I have to call aroundThere are many threads on this subject....go to the search function and simply type "200 mph" and many threads will pop up...
Although they all will point towards the same advice @sixpack577 gave you, they still make for interesting reading.
The ideal scenario is to flash and dyno tune the bike to make sure the A/F is spot on....but even a good flash by a well known tuner can get you real close..Yeah it can be a bit confusing. I called a shop and they said they didn't have the software to flash ecu so I have to call around
Ok I will look them up. So if I have them flash my ecu for my new brocks exhaust do I still need someone to tune it on a dyno?As @Bumblebee stated
Contact Moore Mafia in South Carolina for an ecu flash with an air/fuel map on it also.
That way you don't need the Power Commander.
No, the base map they'll load on there will be sufficient.Ok I will look them up. So if I have them flash my ecu for my new brocks exhaust do I still need someone to tune it on a dyno?
Maaan you guys helped me so much. Also......where is the ECU located lol?No, the base map they'll load on there will be sufficient.
It's just an a/f map from another dyno'd gen2 with an Alienhead, and it'll work fine.
Good, I'm glad we could.Maaan you guys helped me so much. Also......where is the ECU located lol?
good idea to find someone who knows the flash-program well.So should I not purchase the PC and just find someone to flash the ECU for the A/f map?
download the gen2 manual 4 free hereMaaan you guys helped me so much. Also......where is the ECU located lol?
