OB_bigabusa
now building the bigabusa. the cranks come in lighter than my falicon 5mm super crank. the new crank weighs 22.4 pounds. the rods weigh a little more than stock will give an exact weight when i get my gramme scales back from repair. The only case clearancing has been around the bottom of #1. nothing major, just where the case gives clearance for the balancer shaft installation.
for those of you who don't know about this project: the billet crank is 8.5mm over on the stroke (71.5mm) it's made from EN40T fully cross drilled, nitrided and ground. runs without the balancer shaft gear. it runs 40mm big ends (std's 38mm). the rods are machined all over steel forgings made shorter so not to push the 84mm JE pistons out the top. once proven the whole package will be up for sale. i should have pictures on my webb site soon. www.tts-performance.co.uk.
