GIXERHP, I got my bike in the shop for other work. However, if I want to take out the Fuel Pump and clean out the fuel mesh filter, how hard of a job is this? Anyone done this before? If you get the fuel pump out, what chemical or liquid would you want to use to clean the mesh filter with and get the fuel pump clean? Anyone done this. GIXERHP, I am thinking 12,000 miles. Would sea foam work to do this? Suggestions, I had some hesitations/die at over 100 MPH when I hit the throttle, I was thinking this. Shop is doing other things they think was the problem like a oxygen sensor and issue with that and the Power Commander 3 that is on the bike. However, if I get the bike back and it is the fuel pump/fuel mesh filter, I wanted to clean it. Thoughts?
Thanks....all that respond.
