How many of you have cleaned your fuel mesh filter or replaced it as preventative maintenance? My 08 is running perfect I think, just wondering if its worth it to open the tank and check it or replace it. Over time, you might not notice the gasoline flow is not as smooth as new.
Service Manual says, "Warning...the o-ring on the tank must be replaced with a new one to prevent fuel leakage if you open the tank".
Your thoughts?
Your thoughts?
