I have an '01 as well. Lift the tank (remove the two head bolts) and look down the right side. Just below the throttle cables there is a screw, that is your adjustment. You will know it when you see it, it will scream adjust me. It looks like a bolt with a Philips head slot and there is sort of a spring around the threads...
Hope this helps...
