Ok guys it's been a long time since of posted but I need your help. I'll try to make this as detailed as possible.
Last fall I installed HIDs and parked my bike for the winter. My bike sat until about 6 weeks ago. I replaced the battery then. Rode it to get inspected and parked it. 10 days ago I rode to work in the morning(about 11 miles). About 3/4 of the way there my high beam started to flicker very fast. I turn them off and used lows the rest of the way to work. At lunch I try to start my bike and it wont. It tries to turn but not enough juice to start.
I charged the battery at 2 amps until the charger said full (around 4 hrs charge time). Rode home, Rode to work the next day, rode yesterday for 40 minutes. All with no problems. I always ride with high beams unless i'm around other cars at night.
Today I Turn my key on getting ready to start my bike. Highs come on and are flickering. I turn them off and start the bike. I ride 25 miles (with high beams on) and stop for gas. After pumping gas the bike wont start. There was just enough battery to do maybe half a turn.
I coast start the bike, abort my trip and head for home. I ride the 25 miles back home with low beams only.
As soon as I got home I shut the bike off and restarted it 4 times with no problems. Which makes me think its my high beam is causing the problem.
I charged my battery until full again. After being off the charger for an hour the battery read 12.98 volts on my meter.
I installed the battery into the bike. Connected my meter to the + and- on the battery and here are the voltages I got. The first number is volts with low beam only. The Second number is volts with the high beam on.
With bike off- 12.98 volts
Key on, bike not running - 12.38 12.21
Idle 1100 RPMs - 12.60 12.30
2500 RPMs - 12.95 12.48
5000 RPMs - 13.01 12.49
After 5 minutes of testing run time(bike shut off) - 12.75 volts
I would appreciate any help. I have no idea if these numbers are normal. Im not much of a mechanic but would like to fix this problem myself.
Thanks in advance. My bike is a 2005.
