Did all the tests on the charging system and to see if anything was draining the battery.
Ther verdict is the charging system is goo. at 1,500 RPM i get 15.2 volts on the battery and when the bike is off I get 12.5 volts.
I get a 20.6 mA draw on the battery when it is off which is normal because of the clock.
So the final verdict is that the MotoBatt battery was a POS
And the Fast By Gast PB-2 is a monster battery Cutting my seat in an hour to fit the battery in
Pashnit carries them
Thank you AJAY for all the help with everything. Much appreciated
