Hi all !!! I've owned a few busas at this point and just took the plunge into the turbo world (I've purchased a velocity stage-one on an '02 that was tuned by EFR RACING) my previous bikes were big bore KZ's and modified busas (nitros mainly) Ive been reading alot on the org about meltdowns and other engine related disasters. I'm sure I will be asking for advice often in the upcomming months before the ridding season begins.
But lets start here..... I've heard alot that high speeds should be considered a "no-no"..... "high speed runs are for naturally aspirated bikes"!!!...... "DONT STAY IN THE BOOST TOO LONG YOU'LL MELT A PISTON"!!!!!! YIKES !!!!
So I guess I'm asking about what is safe for a perfectly tuned turbo engine. can i do a 6th gear "roll on" from say?? 65 mph up to 180 mph without a downshift?? is that staying in the boost to long??? Can I even take it up to 180 mph ?? or does it take too long to reach that high of a speed and forces me to stay in the boost too long?? Also... ater I run it through the gears once or twice, how long should I cruise to let it cool down before I can go into the boost again?? Should I shift at the factory red line on the tach or should I short-shift to keep the RPM's down where it might see less heat??
Mine is a 2002 with stock internals, velocity stage one tuned by Elton @ EFR.
No water injection or intercooler, tuned for 93 octane pumg gas ( 240 hp @ 7 or 8 lbs of boost) I'm planning on using 100 octane fuel thats available at a local gas station as a precaution.
I'm sure I will get different oppinions, thats fine, I'm open to all opinions at this point.
Thanks guys
Thanks guys
