69ls1
I am going to build a new turbo engine this winter. I currentely have a Stage 1 RCC turbo kit. I am planning on replacing the rods and pistons and going to the S2000 injectors. I would like to run around 12 to 15 pounds of boost and possible with a 2 stage boost controller. I want to still run pump gas on low boost then swich to c-16 on high boost for the dragstrip. I was wanting to know what compression ratio would be the best for both street riding and racing? I am looking at either the 8 to 1 turbo pistons or a 9.9 to 1 pistons. I am not sure if using the 8 to 1 pistons the engine will lose to much power when not in boost while street riding? What are the recommendations for each? What would the max boost on pump gas with the low compression and the S2000 injectors? Any other recommendations would be appreciated.
Thanks.
Thanks.
