- Joined
- Jul 6, 2018
- Messages
- 33,105
- Reaction score
- 56,375
My Ram shows which tire is low (or high) and is pretty easy to sort out although in 5 yrs it has only indicated once (the other day). The Ram indicates in Kilopascals instead of PSI, I have yet to find out how to change that as the gauge I have registers in PSI.My 2020 BMW's are flawless and user-friendly. Roll the magic dial by the left grip to "bike", hit the up button, and a diagram of the bike displays with the psi clearly marked and easy to read at speed. Also, the sensors are inside the rim and the factory valve stems are 90 degrees. It's super easy to put air in the tire (stems are standard threaded type), and you can't steal the sensor as it's in the wheel. If you have the aluminum wheels (mine are spokes) the stems are on the strut of the wheel, not the rim - genius.
Some older cars like my Honda (2013) check relative pressures between tires and alarm constantly even after adding air. One day I was reading the manual and found out that there is a hidden button under the dash you push to recalibrate the system. Do that and the alarms get manageable. The newer ones like the ones on my Ford are awesome and like the BMW show a diagram.
I think it might be the sudden change in ambient outside temperature which affects them most, the transition to cold makes them act up sometimes.
